Phantom 3P falls out of sky
Discussion in 'Pro/Adv Discussion' started by JHammy123, Dec 27, 2015.
  1. JHammy123
    I was flying my phantom on vacation. I was 300 feet up about 100 feet out. No big deal but i lost signal instantly. It didn't get weak like it normally does when your too far away. It just cut out. Moved my controller to try to get signal. I hear it buzzing out of the sky and into the water. What happened? Will DJI refund me as flyaway if i send my flight log? I have recording up until I lost signal.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    DJI is not going to refund you just because the signal cut out. That could easily happen if something blocked the signal, you faced the remote controller away from your Phantom, etc. Post your logs here if you'd like people to comment on them.
    Lonewolf and Lauro Fontoura like this.
  3. JHammy123
    Why would a signal loss result in it plummeting out of the sky? Ive lost signal several times and it just hovers.
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    A lost signal will not cause it to fall out of the sky. Check out your logs. They should tell you exactly what happened.
  5. JHammy123
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Your logs are saying you took off at 63% battery and your battery shut off when the voltage hit 3V as you made the steep climb at the end of your flight. Was the battery at 63% on takeoff?
  7. JHammy123
    No fully charged. It was maybe at 95% by the time i took off. But the props were still spinning when it hit the water. I could hear it buzzing.
    Thank you for your help.
  8. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Odd. Your log stops when your Phantom is 357 feet in the air.
    Did you take off multiple times with that same battery? And, did you see 95% in the DJI GO app?
  9. JHammy123
    That is when I saw no signal. I was gaining altitude, looking around. I saw the landing gear in the bottom left of the screen and boom no signal. I can see the archived recording on my ipad. The recording stopped when i saw no signal.
  10. msinger
    Approved Vendor
    Harrisburg, PA (US)
    If the battery shut off (which is what your logs indicate), it would make sense for the video to stop and the app to show no signal.
  11. JHammy123
    What is my next step? Suffer with my loss?
    Did my flight logs say i had good voltage up until the 3v no signal?
  12. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I'm still curious about one thing. How did you know the battery was at around 95%? Where and how did you verify that?
  13. JHammy123
    I checked the battery before i put it in the phantom by pressing the button, said full bars. I had just fully charged it recently. Assumed it was at 95% as it normally is when I take off. Dont my flight logs say?
  14. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Your logs say the battery was at 63% on takeoff. That means you would have seen 3 lights illuminate when you pressed the battery button to check it.
    It's best to check the battery level at the top, right of the DJI GO app.
  15. JHammy123
    Im very certain i saw 4 bars. I have many batteries i would have used a different one if it was at 3. What was my voltage all the way up to the crash?
  16. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Your voltage was at 12.098V when the log stopped. There are 4 cells in the battery, so that works out to an average of 3V per cell.
  17. JHammy123
    So was my voltage good when I took off? Im wondering if the battery just dropped to 3v then dropped.
  18. GregWV
    Bluefield, WV
    Were you able to recover the Phantom?
  19. dirtybum
    What is you on the new 1.6.4
    In any case I would still contact them and see if this is a classic case that we been dealing with with 1.5.3 a battery shutting off midflight you won't know if they'll work with you unless you try
  20. JHammy123
    No, I know where it landed though. Its in about 7 foot of salt water. I have a buddy that scuba dives, might have him come over and look for it. What is it worth?
Similar Threads - Phantom falls sky Forum Date
Phantom 3 Standard falls out of sky and almost injures people Standard Jun 11, 2017
Phantom 3 S falls out of the sky at 300 feet Standard Nov 23, 2016
Phantom 3 falls out of sky - hits woman in head Pro/Adv Discussion Jun 26, 2016
Phantom 1.1.1 Falls from sky - Apparent battery failure? Phantom 1 Discussion May 17, 2015
A' Bhuidheanach Bheag Waterfalls with snow, Drumochter pass, Scotland - Phantom4 Photos and Video Nov 29, 2017
