Please post the TXT file here.
And, one of those was 1.3.2?Since then I have tried 2 newer firmware files and both times the light instantly went green but neither time have I had a .txt file after disconnecting??
Are you sure you grabbed the right 1.3.2 BIN file from my site?
The links on my site are good. I just wanted you to doublecheck that you have the correct file. When using a BIN from another P3 model, nothing happens when you attempt to install it.
Correct. The filename starts with "P3X". If you haven't already done so, try downloading it again from here. Make sure you delete everything on your memory card before dropping the BIN on it.
