Standard phantom 3 standard
Discussion in 'Phantom 3 Help' started by Bronx_Bomber, Dec 1, 2015.
  1. Bronx_Bomber
    hi. I just purchased a new phantom 3 standard. I love this machine but I need help pls. here is my story. I setup my bird did the firmware update all well , did the imu calibration and it was good. now my phantom turns on and the motors start up. but I have solid red led's in the front and slow flashing yellow in the back. what does this mean? anyone it would be greatly appreciated. I am physched to be a part of this phantom community. thank you and hope to hear from someone soon. so maybe I can sleep tonight. lol
  2. Bronx_Bomber
    my first post newbee here trying to figure this out
  3. barefootbeachcombing
    US
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    That means you're in ATTI mode. That'll happen when your Phantom does not have a connection to 6+ satellites or when manually put it in ATTI mode. Here's the blink pattern from the P3S Manual:
  5. Bronx_Bomber
    than you very much greatly appreciated. will do
  6. Bronx_Bomber
    thank you very much for that. ok so solid red in the front is normal?
  7. Bronx_Bomber
    hi another newbee question. what mode should I be flying my p3s? I will be using it for recreation
  8. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    It is a pleasure to welcome you to the Phantom Pilots forum. I hope that you will take advantage of the benefits that come with membership and that you will be able to use the forum for the exchange of innovative ideas and as a resource for current developments in Phantom quadcopter’s.
    That is normal. I would suggest you go over this information throughly. It will help you to learn the operation of your new bird. - https://dl.djicdn.com/downloads/phantom_3_standard/en/Phantom_3_Standard_User_Manual__V1.4.pdf
    You definitely want to know as much about it before you get into the air and into trouble. ;)
  9. Bronx_Bomber
    Thank you very much. I have already begun reading, you guys are awesome
Similar Threads - phantom standard Forum Date
Phantom 3 Standard ARGtek controller signal weak General Discussion Today at 11:31 AM
Standard Phantom 3 standard limitations Phantom 3 Help Yesterday at 4:19 PM
Phantom 3 standard no SSID help Standard/4k Discussion Wednesday at 9:33 AM
Standard Phantom 3 Standard, 5.8ghz pepperbox 23rd birdside? Phantom 3 Help Aug 14, 2017
Standard phantom 3 standard Phantom 3 Help Aug 13, 2017
