- Joined
- Mar 17, 2015
- Messages
- 211
- Reaction score
- 32
I can confirm that the rubber damper on the P2V+ is slightly different from P3. P3 has softer rubber damper. The other day I was swapping my P3 rubber damper to P2V+ one and was having a very bad jello effect. So, in case you need to replace those dampers, make sure you use the ones that are made for P3 which are softer. They might look the same but they just don't fit the same.
