Phantom 3 Ribbon Loose
Discussion in 'Pro/Adv Discussion' started by Jason Catterall, Jul 27, 2016.
  1. Jason Catterall
    Have a phantom 3 advanced. The ribbon cable next to the camera underneath, seem to drop a little while flying, when I notice it I push it back up. Could it be loose or is this normal, with gimbal movement, it drops a 3-4mm.
    Jason...
  2. Dronason
    Switzerland
    Please send some pictures with some indication where you have the 3-4 mm drop as some of the ribbon cable area are made to absorbe the movement of the camera and some are not moving.
  3. Jason Catterall
    Hi there, thanks for reply, I have the p3 advanced. I noticed the movement after a old sd card that went bad(Sandisk ultra) and I lost feed. Before checking I noticed the ribbon had moved. I took this picture before pushing in, however I don't think it had come out of socket. More like you said, there is movement for gimbal.
    The sd card I then checked, which was bad and would not format. I have since changed for a Sandisk extreme pro. I think all is good. Connections look good. I was concerned as I have only had the drone a few months and flown only a few times.
    I think ribbon is like you said, for movement. Will see if it moves and take a pic after next flight. And think the sd card I had was no good also.
    Jason
  4. Jason Catterall
    Here's another pic, connection looks good to me.
    Jason
  5. Dronason
    Switzerland
    This one should not be loose, it should remain in place as it is not part of any moving item in the gimbal. What seems important to me is that the connector part of the ribbon cable is fully inserted in the small white connector. This is delicate parts so be careful if you touch or push it.
    Here are some pictures of mine (P3A too):
  6. Jason Catterall
    Thanks for all your help. I am now thinking it's just movement of ribbon as connector is ok.
    Jason.
  7. Dronason
    Switzerland
    Yes, from yours pics it sounds ok. I would expect that from manufacturing there are some difference in distance and place of the ribbon cable.
Similar Threads - Phantom Ribbon Loose Forum Date
Phantom 3 professional - ribbon wiring ? Pro/Adv Discussion May 22, 2017
Phantom 3 Standard - Ribbon cable broken? Standard/4k Discussion May 5, 2017
Standard OFDM Phantom 3 ribbon Cable Phantom 3 Help Feb 6, 2017
Standard Phantom 3 ribbon break Phantom 3 Help Dec 31, 2016
Aluminum Gimbal Motor and Ribbon Cable Protector Kit for DJI Phantom 3 Professional and Advanced Pro/Adv Discussion Dec 15, 2016
