Phantom 3 Pro video error...
Hi all,
Firstly hello! New to the community.
I have a P3P when I record in video on the playback it has what I can describe as pink flashes and very jumpy on the playback.. Can anyone suggest what might be causing the issue and how I can fix?
Anyone in the UK can you suggest any certified Drone repair/service shop to give it a service..
Thank you,
Matt UK
Issue:
Flex Flat Cable damage
Fix:
Buy new one, replace.
See YT vids for tutorial
Buy double sided one, as cheap ones either do not work or give noisy video.
Note:
This diagnose only applies if footage from SD-card recorded in the drone has the artifacts. If the issue is only with FPV, and not with the videos recorded within gimbal - then the cause is different.
Reactions: RodPad
Issue:
Fix:
Note:
Thank you for the response. Yes just on playback it seems to happen.
Reactions: RodPad
