Professional Phantom 3 Pro - No Signal
Discussion in 'Phantom 3 Help' started by Mike Orland, Aug 15, 2015.
  1. Mike Orland
    I just updated my P3P to the latest firmware update and updated DJI Go as well. I continuously lose signal. Most of the time it won't even connect, and if it does, I lose signal (No Signal red box on top of screen) as soon as the copter moves. Any suggestions? How do you even troubleshoot something like that? I also used my phone and tablet and it does the same thing.
    Poundofnuts likes this.
  2. Altanore
    AB, Canada
    Did you update the controller as well?
  3. Mike Orland
    Yes, I had numerous failed attempts when updated latest firmware on copter, however today it updated no problem. The controller updated fine. I was having a problem with 'no signal' even before I updated firmware.
  4. RoyVa
    Virginia
    Did you try rebinding the Tx to the Phantom. Be sure All firmware is updated.
  5. bobmyers
    San Antonio, TX
    Check your cable-- try another one
  6. Mike Orland
    Where can I find a video on how to bind. Not sure of the sequence.
  7. Garrie
    Singapore
    You can find the option to bind the remote to the aircraft in the menu. Open up your app and go deep into the menu to find it. I can't tell u exactly how to bind right now but I can tell you I've seen the option to bind in the menu. So just probably follow the onscreen instructions.
  8. bobmyers
    San Antonio, TX
    its in the manual
  9. gregkernaghan
    Latest software "update" bricked my brand new Phantom 3 Pro with the same NO SIGNAL issue... good lucking withj a fix - been trying everything for a week - total time shred and no worthy support from DJI - they obviously know they messed up with this as there are so many folks with the same issue
  10. Michaelangelo
    Same problem here. Almost lost it last night. Not flying anymore. I've tried everything.
  11. VickyMarie
    The South of England
    Flight no 32 yesterday with my P3P. All firmware up to date, everything calibrated, yet yesterday, at a distance of only around 300 feet and no higher than 100 feet, suddenly, No Signal. This follows 31 perfect flights. No view from the camera and no telemetry on the iPad, but the craft was responding perfectly to the controls, except the red button to stop video recording didn't. I landed immediately, successfully. Today I've had 2 thoroughly perfect flights.
    My thoughts: K-index was 5 yesterday, down to 4 today. I know that many think that K makes no difference, but it was the only factor I could think of. I've read of users refusing to fly if it's over 4. I remember one day with our P2V and a K of 8 that it just wouldn't work or connect or do anything, zero satellites, so I went home! I believe in K.
    Poundofnuts and GlennG like this.
  12. GlennG
    Don't fly unless it is below 4.
  13. Mike Orland
    What is K index?
  14. GlennG
    Measurement of disturbances in earth's geomagnetic field. See UAVFORECAST.com. High index can cause problems with communication systems.
  15. GlennG
    There is also a Magnetology app that provides the index. Works fine too but the URL is better. Best wishes.
  16. VickyMarie
    There won't be many days when it's below 4.
  17. GlennG
    I watch the time slots. I'm in North Alabama so grounded a couple of days. Thanks!
  18. GlennG
    Vicky, how high do you let the index go and still fly?
  19. GlennG
    What is your cut off point on index?
  20. VickyMarie
    I won't usually fly at 6 or above. But after the no signal at 5 I'm revising my view to a max of 4 now. Of course I don't really know if the no signal was a result of the high-ish K but best not to risk it I feel.
Similar Threads - Phantom Pro Signal Forum Date
Phantom 4 pro battery signal error? Phantom 4 Pro Help Jan 12, 2018
Phantom 4 Pro Losing GPS Signal Phantom 4 Discussion Jan 1, 2018
Phantom 4 pro + Image transmission signal weak General Discussion Dec 30, 2017
Phantom 4 pro signal drops out?? Phantom 4 Pro Help Dec 30, 2017
DJI Phantom 4 Pro Go app has "No Signal" Phantom 4 Pro Discussion Oct 15, 2017
