Phantom 3 Controller Does not Charge
Greetings,
Just recived my Phantom 3 Pro, charged main battery then when tried to charge the controller i did not get the charging led indicator (moving led from left to right). Led's light up promptly then off. Had it connected overnight, still did not charge. I posted a short video on youtube showing the problem:
Hope anybody/support can help. Hate to have to return it and wait for new one to be available.
Maybe you are having a defective charger like mine before. Mine did not charge battery and controlller out of the box and got them replace from local dealer about a week after.
My charger charges main battery fine.
Two different leads-- maybe the controller lead is bad
same here, I just purchased my P3P yesterday and the remote controller doesn't charge. battery charges just fine.
There's something wrong with the charger.
omg I just retried and found out the solution! a little twist for the connection head will fix the problems! works fine now!
Try and tell me if it works for you
I don't get it, you mean twisting the head around the port while plugged? I did that countless times with no result!
if someone has already solved the problem? I have the same, charged the controller, I updated the firmware is 1.19, I made 10 flights, and I can not charge the controller.
Confirmed - same thing here: charge main battery ok, controller not.
Solution: plug ALL the way in with a rather firm action, then turn/twist the connector until you see the little white led is on, then leave it there.
Reactions: MarkOD
Pauos31
