Advanced Phantom 3 Advance Firmware Issue
Discussion in 'Phantom 3 Help' started by guards, Aug 16, 2015.
  1. guards
    Regina Canada
    I have tried many times to update the Firmware on my Phantom 3 Advance. I keep getting a message that tells me the file is corrupt. Have tried multiple SD cards but it keeps telling me to update from DJ Phantom which I tried and tried. The firmware that I started out with was 1.2.8 on the drone and the radio controller is 1.1.0 But when I look the firmware on it now 1.2.1.06 Below is the error message I keep getting. Anyone got any ideas?
    Result: Corrupted.
    Firmware bin file is corrupted, download it again from the DJI offical website.
    ========== 2014.01.01 00:00:11 remo-con disconnect======
    Packet: P3S_FW_V01.02.0007.bin
    Upgrading ...
    Result: Success.
    ========== 2014.01.01 00:00:10 remo-con disconnect======
    Packet: P3S_FW_V01.02.0008.bin
    Upgrading ...
    Result: Success.
    Packet: P3S_FW_V01.03.0020.bin
    Upgrading ...
    Result: Success.
    Result: Abort.
    The firmware on the SD card is identical to or older than the current firmware on the aircraft.
    Result: Abort.
    ========== 2014.01.01 00:00:12 remo-con disconnect======
    Result: Abort.
    Upgrading ...
    Result: Success.
    Result: Abort.
    Result: Abort.
    Upgrading ...
    Result: Success.
    Upgrading ...
    Result: Success.
    Result: Abort.
    ========== 2015.08.11 23:14:18 =====================
    Result: Abort.
    Result: Abort.
    Result: Abort.
  2. bobmyers
    San Antonio, TX
    Are you trying to update the FW on the P3 with the RC turned on?
  3. bobmyers
    San Antonio, TX
    It looks like you have the older text files still on the SD card and the upgrade is adding to those text files. Format the SD card, extract the bin file to the SD card or extract it to your computer and copy it to the root directory of your formatted SD card.
    Do the update again on the aircraft. You will probably find that the upgrade is successful.
    Post that text file. It looks like the update was good from what I can see.
  4. guards
    Regina Canada
    No I am not, RC is turned off
  5. bobmyers
    San Antonio, TX
    check my last post
  6. guards
    Regina Canada
    I have tryed 2 different sd cards several times and always formatted before reloading bin file from dji
  7. bobmyers
    San Antonio, TX
    delete all the text files and rerun it and I can compare them to my text files.
  8. guards
    Regina Canada
    I've done this several time and it is the exact same error message word for word as in my posted message above.
  9. guards
    Regina Canada
    Here is the message I get after I format the card and redownload etc.
    Result: Corrupted.
    Upgrading ...
    Result: Success.
    Upgrading ...
    Result: Success.
    Upgrading ...
    Result: Success.
    Result: Abort.
    Result: Abort.
    Result: Abort.
    Upgrading ...
    Result: Success.
    Result: Abort.
    Result: Abort.
    Upgrading ...
    Result: Success.
    Upgrading ...
    Result: Success.
    Result: Abort.
    Result: Abort.
    Result: Abort.
    Result: Abort.
    Result: Abort.
    Result: Abort.
    ========== 2015.08.13 23:44:33 =====================
    Result: Abort.
    Result: Abort.
    Result: Abort.
  10. guards
    Regina Canada
    The Firmware file in there now says its 1.2.1.06 which is not even a phantom file?
  11. guards
    Regina Canada
  12. guards
    Regina Canada
    I have refomatted the sd card and am sending to you to match up the file results,Iam concerned about the fact that always says corrupt each time I run it & my FW on copter shows 1.2.1.06 ,my FW on RC is 1.1.0 ,it flys ok but scared to load new RC, FW Thank You In advance for any help you can give Guards
  13. bobmyers
    San Antonio, TX
    Need some more information-- What kind of cell phone? Android or IOS (Apple) What is the model? Do you have the DJI GO APP installed? Latest version. Have you upgraded the firmware on your P3.. Need a lot more information on your setup and equipment to give you an answer.
  14. Steve Shead
    San Jose, CA
    I hope this isn't stating the obvious - but - your text file says P3S - you're flying a P3A right? Are you 100% sure you have the right firmware file?
    Mako79 likes this.
  15. Mako79
    Sydney Australia
    LOL. Nice spot :) maybe if he uses the "S", he'll get the 2.7K reso.
    Steve Shead likes this.
  16. Steve Shead
    San Jose, CA
    Prior to the new firmware it might have been worth a try :D ...now that 2.7k is available for the P3A, not so much! :rolleyes:
Similar Threads - Phantom Advance Firmware Forum Date
phantom 3 advance camera and firmware issue Pro/Adv Discussion Sep 4, 2017
Phantom 3 Advanced Latest Firmware???? Pro/Adv Discussion Jul 29, 2017
Advanced Phantom 3 Advanced Firmware Update Confusion Phantom 3 Help Jul 11, 2017
Phantom 3 Advanced Firmware Update Pro/Adv Discussion Apr 24, 2017
Are these Firmware versions of with my Phantom Advanced Pro/Adv Discussion Feb 13, 2017
