P3 Firmware Phantom 3 Adv/Pro updates without camera
Discussion in 'Firmware' started by Sageline, Jan 8, 2016.
  1. Sageline
    Can the firmware be updated on the aircraft/battery, if a camera/gimbal is not installed ?
  2. bbfpv
    Long Island, NY
    no. where would you put the SD card?
  3. Sageline
    Was wondering what the mini USB port is for on the front of the aircraft, thought you could use it for something, come you connect to the aircraft thru a browser
  4. Crunch97
    Been there before. Have to use camera.
  5. skygear
    Could i swap in an updated P3P to an older P3P with NO camera to do the update?
    Would there be compatibility issues swapping the 4k Pro camera back and forth?
    Tried the crashed board from the gimbal already and it will not update, feeling it is not initializing since the camera is gone. Let it sit for 40min 'updating' and through the flashes it was doing the red green but no noise since the camera was gone.
  6. PeggyBatres
    Have to use camara.
  7. skygear
    That was the question... I will be using the camera, but I wanted to know if there would be a compatibility issue since I would be swapping a current firmware camera to an older firmware P3P.
    ....**** the torpedo's, full steam ahead.
  8. Crunch97
    No it should work fine.
Similar Threads - Phantom Adv Pro Forum Date
Problem with my New Phantom 4 Advanced plus Phantom 4 Discussion Monday at 3:24 PM
Need some advice on the Phantom 4 Pro - used Phantom 4 Discussion Monday at 1:10 PM
Phantom 3 advanced crash (Probably Compass issue) Pro/Adv Discussion Aug 15, 2017
Phantom 4 Pro Advanced POI test of Guilderton Lighthouse in Western Australia. Photos and Video Aug 11, 2017
Phantom 4 Advanced - Disconnecting problem Phantom 4 Pro Help Aug 5, 2017
