Phantom 3 & 4 factory lens removal tool
Discussion in 'General Discussion' started by BigAl07, Aug 28, 2016.
  1. BigAl07
    BigAl07 Moderator
    Staff Member
    Western North Carolina
    Today I tried to remove the factory lens from my Phantom3 Pro platform. Up until today (1 year 2 months) I've never thought about it let alone tried to remove it. But I've got a Polar Pro set of filters coming next week and I'll need to remove the factory lens cover. I've read thread after thread about tips and tricks on how to do this. They include:
    • 1) wearing rubber/latex gloves gently gripping front of the lens and rotating
    • 2) using rubber band etc gently wrapped around the lens barrel to allow good grip but light grip
    • 3) heat applied to the lens barrel
    I tried #1 and #2 but opted to NOT try #3. Unfortunately not amount of "finesse" would get it loose. I just happened to remember a "bottle cap removal tool" (twist off like on Coke/Pepsi bottles) I got in the mail at work recently as a promotional item. It's designed to apply pressure to the "bottle cap" in a uniform way to make it easy to remove a stubborn cap.
    I grab it, push it against the lens cap and twist. Shockingly it rotates immediately and easily. Below are some images (From the internet) of the tool I used:
    [​IMG]
    [​IMG]
    If you've got one of these or something similar it might be worth a shot. I'm still amazed at how easily it came off using it. I'm not going to admit how many times I tried it the other ways LOL. Needless to say this is going into my flight case immediately. :)
    Good luck and SAFE flights :)
    Allen
    Jonathan Huff and dirkclod like this.
  2. Mocho
    Alberta, Canada
    Great find!
    Thanks for sharing, this should help a lot of people.
    From a mechanical point of view it looks like the perfect tool for the job! The device will contact the edge of the filter, which is the strongest part. Even pressure around the edge of the metal ring but no deformation of the threads themselves!
    If this tool doesn't work then your threads are likely too corroded and u will likely need a small amount of WD40, then the tool to work the lens cover off.
    Should be easy to find at your local Kitchen store as well.
    BigAl07 likes this.
  3. Mike_in_Letcombe
    Letcombe Regis, Oxon, England
    I FINALLY undid mine yesterday, with some rubber washing up gloves. Nothing else worked but these got it undone first attempt! Thank my wife for the idea...
  4. QuadBart
    USA
    It is amazing just how little pressure is required to remove the filters.
  5. Fifty7
    I used one of those rubber pads made for gripping a jar cover. Came off very easy. Now I just need to make some time to try my Polar Pro's.
    BigAl07 likes this.
  6. Martin Smith
    Clermont, Florida
    Yup, the real trick it the lens needs only to be rotated and not squeezed at all.
  7. Kima kim
    ??? Would anyone know if the P3A also have a "factory" UV lens filter out of the box?
  8. BigAl07
    BigAl07 Moderator
    Staff Member
    Yes it sure does.
  9. Doink
    Derbyshire, UK
    Why can't you just use the prop removal tool, does the same thing
  10. daveleeds
    Alfreton, between Chesterfield and Derby
    What works for me is just to put the iPad/Samsung, whatever lead around the cover, hold the lead together where it meets and without your fingers actually touching the cover gently turn it.
    BigAl07 likes this.
  11. BigAl07
    BigAl07 Moderator
    Staff Member
    That's an excellent idea.
  12. Kima kim
    Thanks!
  13. Noodle
    Sydney, Australia
    I just tied rubber band around the circumference of the lens and it unscrews easily. So much cheaper too :D
    GPSMapNut likes this.
  14. SoDoWarts
    I used a Quitip with a little WD, waited 5 minutes and with some light finagling -- voila!
Similar Threads - Phantom factory lens Forum Date
WTB:DJI phantom 4/pro factory box and foam case Classifieds Jun 13, 2017
DJI Phantom 4 factory sealed, retail boxed unit. Brand new + extra new battery. Classifieds Apr 28, 2017
For Sale: Phantom 4 Professional (Factory Refurbished) Classifieds Feb 1, 2017
resetting phantom 4 to factory settings Phantom 4 Discussion Jan 11, 2017
Standard how to make a factory reset to phantom 3 Phantom 3 Help Jun 29, 2016
