Phantom 3 2.7k camera
Does anyone think dji will put a 2.7k camera on the advanced? because I would like to wait and see if they do before picking up that model.
Doubtful. I'd assume you'll be able to switch out the camera between the S and A like you can do w/ the A and P.
Reactions: ashtonhess
From what I've read, even though the Standard has 2.7K, it doesn't use the same Sony sensor that both the Advanced and Pro use. I'll stick with the higher quality sensor and 1080P personally.
Reactions: AlmostTan
Where did you read this? I'd be surprised if it's not the same sensor. It could be the same imager used in the Hero 3 black but I'd like to confirm that.
I don't know who I have to beg at DJI to get 2.7K on the P3P. 65 Mbps, 48p, please!
The camera seems to be quite different.
from DJI:
Phantom 3 Professional
UHD: 4096x2160p 24/25, 3840x2160p 24/25/30FHD: 1920x1080p 24/25/30/48/50/60
HD: 1280x720p 24/25/30/48/50/60
Phantom 3 Advanced
STANDARD
UHD: 2.7K: 2704 x1520p 30 (29.997)FHD: 1920x1080p 24/25/30
Sent from my Nexus 5 using Tapatalk
No details in the Engadget article. Unless they did a teardown, I am going to guess they don't know any better than we do.
According to DJI's site, the spec looks pretty much identical. And the only hardware I know of that has a 2.7K mode is the Exmor / Ambarella combo.
Sensor 1/2.3” Effective pixels:12 M
Lens FOV (Field Of View) 94° 20 mm (35 mm format equivalent) f/2.8
ISO Range 100-3200 (video) 100-1600 (photo)
Electronic Shutter Speed 8s -1/8000s
Image Max Size 4000 x 3000
cgarner1
