Phantom 2 Zenmuse Go-Pro... Which Set Up? (Monitor, FPV etc)
Discussion in 'General Discussion' started by justicebentz, Dec 26, 2013.
  1. justicebentz
    Hi guys,
    Sorry if this is a repost, have spent several days trying to figure this out and getting frustrated. Already own a VISION (and will keep it for photos) but want to film better video.
    I ordered a PHANTOM 2 w/ ZENMUSE Gimbal, however want to know what set-up you guys are using w/ stock transmitter, monitor (w/ cover), iosd, etc?
    If you had links for each part that would amazing..
    Again sorry if this is a repost, I just live in a country where it's not easy to get parts and just want to make sure I order everything I need to make it compatible
    thanks so much everyone.
  2. justicebentz
    Re: Phantom 2 Zenmuse Go-Pro... Which Set Up? (Monitor, FPV
    What else do I need?
  3. LeoS
    You need to read the thread about DroneFly's customer service :)
    Seriously though, will you be using GoPro hero as the FPV cam? Does the P2 already come with video cable for it?
  4. OI Photography
    Clarksville, TN
    The zenmuse handles the video-out for the gopro, at least the current one does (I'm assuming the one shipped with the P2 does as well).
    justicebentz, it looks like you have the items you need on your list there, you'll just need a way to mount the video Tx on the phantom, and power the monitor, but other than that you're covered there for basic FPV. Also, be sure the receiver in that monitor works with the specific 5.8GHz channels that DJI uses (along with others).
  5. justicebentz
    Changed order as the Monitor already has a Rx, so dont need the Rx.
    Yes will be using gopro as FPV only for framing as i will mostly be flying within sight of Phantom 2
    Assuming by the tone that Dronefly customer service is bad???
  6. justicebentz
    Ok looking now for a power source for monitor... Any parts I need to order to mount the Tx on Phantom2?
  7. justicebentz
    Here is updated cart.
  8. Ksc
    Ksc
    Naples, FL
    You would have better service with buying from a Chinese seller on eBay. Stay away from dronefly.
    The dji fpv setup is good but heavy. I prefer the fat shark or immerrsionrc setup. Less weight means more flight time.
  9. justicebentz
  10. OI Photography
    Clarksville, TN
    That's a decent setup, but too expensive. This one will get you everything you need, except a mount to put the monitor on your controller if you want that (instead of a tripod mount): http://www.readymaderc.com/store/index. ... ts_id=2066
  11. Ksc
    Ksc
    Naples, FL
    I second that one.
