Phantom 2 Won't Turn On After Firmware Update
Discussion in 'Firmware' started by abloom123, Jul 16, 2014.
  1. abloom123
    Just did a firmware update, now the four outer LED lights won't turn on after power cycling my Phantom and my H3-3D gimbal is unresponsive.
    There is a red solid light being displayed inside the housing, with another small yellow LED flashing.
    Did this upgrade brick my Phantom / Gimbal?
    (Attached screenshot of upgrade screen)
  2. Pull_Up
    South Oxfordshire, UK
    Firmware showing 0.0.0.0 and garbage characters looks like a bad flash. One way to try and correct this is to use a previous version of the Assistant to flash earlier firmware, then reflash the latest one. Download Assistant 2.0 from the DJI website and try putting the older firmware on, then you can try again with the latest one.
Similar Threads - Phantom Won't Turn Forum Date
Phantom 3 advanced remote won't turn on unless plugged in. Pro/Adv Discussion Jun 8, 2017
Phantom 2 won't turn on Phantom 2 Help Nov 19, 2015
My Dji Phantom won't work with my Turnigy 9x controller Phantom 1 Discussion Jun 2, 2015
Phantom Vision+ won't turn after first battery charge Phantom 2 Vision + Help Feb 17, 2015
Phantom 2, h3 3d and gopro 3+ won't turn on. Phantom 2 Discussion Jan 2, 2015
