Phantom 2 Vision v3.0 self landing issues.
Just updated my Phantom 2 Vision from the version 2 to the Version 3.0 and since then, if I let the craft land itself, it will come down, and hover on the ground and drift until either I take control or it runs into something. Ran into a car stop in the parking lot, and today, it flipped over on the dirt. In both cases I have damaged my blades because it is not shutting down.
UAV Pilot 4 Fun
Phantom 2 Vision
Sent from my iPad using Tapatalk HD
UAV Pilot 4 Fun
Phantom 2 Vision
If you let it land itself? Do you mean that you initiate an RTH sequence?
-slinger
Yes, I did it to demo it's return feature to co-workers in the parking and that was almost a good demo. Then today, I lots it up I the air and I gave it the RTH command, then I went looking for it, and when I came back to the starting point, it had came back home and landed, then flipped upside down before I got back to it.
UAV Pilot 4 Fun
Phantom 2 Vision
I guess no one else is having this problem, just me :-(
Well I done a recall on the nav, both basic and advanced, and I guess it is time to test it once again.
Phantom 2 Vision
UAV Pilot 4 Fun - Allan
Cypress TX
I always hand catch just for this reason, even in rth mode I still catch it because the lighest of breeze can tip it over.
I had the same issue. It didn't tip over but it did drift into things if I didn't stop it. What i ended up doing is fiddling with the gain settings and that seemed to have fixed it. But the new software does take a while to actually shut off the props but I'd rather that than the silly bouncing it used to do.
jrl
