Phantom 2 Vision - powers up motors wont turn
Discussion in 'Phantom 2 Vision Help' started by Hcky23, Aug 19, 2014.
  1. Hcky23
    Have a Phantom 2 Vision and one of the motors went out during flight. I was about 15 feet above grass when it came down and after putting it back together I was able to power up and 3 of the 4 motors were operational. I ordered new motor, installed it as required by instruction and once all together it powered up with all lights and beeps, but when I brought both controller sticks to the motor start position none worked. I also noticed when checking all the wire connections there was one that appeared damaged. This would be the brown (or tan) wire from the main board and looks to run to the lower part of the battery connection. I might be in a position where I need to send my Quad out for repair unless someone can give me an idea what to do next.
    Mark
  2. nintendrone64
    Simi Valley, CA
  3. tferrari
    Can you take a picture that clarifies which wire is damaged and where it is damaged?
    I have a feeling the ESC may need to be replaced as well, but this wire sounds like a different issue.
Similar Threads - Phantom Vision powers Forum Date
Which app do I use for Phantom 2 Vision+ these days? Software Friday at 4:55 AM
Phantom Vision 2+ Gps Module burnt up Phantom 2 Vision + Help Jan 12, 2018
Phantom 2 vision Wiring Photos please Phantom 2 Help Jan 11, 2018
WTB nd filter Phantom 2 vision + Classifieds Jan 3, 2018
Phantom vision2+ gimble fix Phantom 2 Vision + Help Dec 30, 2017
