As the battery is inserted, the two contact dots on the battery
should make contact with the two mating spring-loaded
plunger contacts in the battery compartment of the P2V.
Since these plungers are said to allow depression of about
3 mm, in use they should be depressed about 1 to 2 mm
in order to make good good contact with the battery.
One member measured his P2V and a battery very carefully,
and concluded that the tips of the plungers JUST BARELY
made contact with the battery's dots.
Assuming this is accurate and typical, perhaps due to a
manufacturing dimension in the battery which recessed
the dots too far, or a manufacturing mis-positioning of
the two plunger contacts, vibration could easily "open"
the contacts.
When I get my P2V next week (shipped yesterday), I
intend to do some careful measuring.
1. On the P2V, measure (A) from the outside face of the
battery compartment to the tips of the plungers.
2. On the battery, measure (B) how far the dots are recessed
from the protective "collar" around them.
3. Then, measure the distance (C) from that collar to the inside
edge of the battery "cap", which touches the outside face of the
battery compartment when the battery is fully inserted.
C - B "should be" about 1 mm more than A, for a "solid" contact.
If A is more than C - B, the plungers will not even touch the dots.
If they barely touch, the contact could be intermittent.
Perhaps others could do the same measurements, and report here.
