Well it has arrived, not exactly sure what has been done, but
upgraded mine and off for a fly.
http://www.dji.com/download/phantom-2-vision-downloads/
mitchsden said:Well it has arrived, not exactly sure what has been done, but
vbluguitar said:mitchsden said:Well it has arrived, not exactly sure what has been done, but
I think it just updated the software on your PC, but won't really change anything on the vision itself. All the firmware versions are from last week. That is where we will see a difference in functionality.
Drone7 said:vbluguitar said:mitchsden said:Well it has arrived, not exactly sure what has been done, but
Yes it is, look at the items below. Also 1.05 for the vision. Lets try and see!
TisiRaptor said:Is this update just out in the US? I am in the UK and just got the assistant to check for a software update and it said no updates available. Currently on 1.01.
Pull_Up said:Aaaaaand I need some help!
Downloaded the updates, had a look around, changed to NAZAM mode to get IOC and other goodies. Noticed you can use the bottom-most S1 to select failsafe, nice. All lovely.
Power cycled everything and now I get my first ever invalid battery! Never had it in flight, and my contacts looks lovely and clean compared to some other pics I have seen. Nevertheless I clean with alcohol, put it back in, power cycle a couple of times and finally presto - I can see my battery status and change the alarm settings to give a bit more range.
Then I notice the Receiver has an update available (must have missed it before). Try to update, it keeps failing. Then I notice it says "Current version 0.0.0.0 - Upgrade 1.0.1.3". Keeps failing. It throws up the big red "only for use with Tx version blah" but I've already had the back off the Tx and done that.
I have tried with Tx on, with it off - I can't see any small flashing link light to say it's lost link but the fact it's showing version 0.0.0.0 implies to me it's gone gaga.
Everything else is latest version, but the Rx appears to have gone awol. Anyone familiar with Naza's know how I can get it back or is this going to be a back to dealer job? Gutted, as it was flying so nicely and now it's a bit of a dead duck. Not sure what else to try, so over to you guys!
wildcatter said:1. Overview: :
a) The Phantom 2 Vision Autopilot's firmware is upgraded to v.1.05.
b) The firmware of Central Board is upgraded to v1.0.1.18
c) The PC Assistant Software is upgraded to v1.05
d) Cell Phone App is upgraded to (iOS App: v1.0.28 Android App: v1.0.33), they are now under app store reviews.
Thank you a thousands times
the update process is a 4 step process
first you hook up the PV and update the driver
then it sees that your firmware is old
then it updates that, or lets you know it needs updating
then you update the first firmware
then you update the auto pilot
then you cycle the PV
THEN IT ALL WORKS AGAIN
Their instructions was not all that clear
k
blueskycam
