Phantom 2 motors not timing out.
Discussion in 'Phantom 2 Help' started by klik, Jun 29, 2014.
  1. klik
    First issue, battery not connecting with pins that power the receiver. How do you keep these clean and a good connection? After loosing connection the quad it went into failsafe mode and flew down and clipped the house flipping upside down on the ground with the motors running at nearly full throttle. The only way to stop it was pull the battery out. Connected quad to the DJI assistant and did all the checks and reset everything. Now the motors do not time out. The motors will run for ever sitting on the ground. They don't time out and turn off.
  2. OI Photography
    Clarksville, TN
    Not quite sure what you mean by "timing out"...do you hold the left stick all the way down to shut them off, or use the CSC combo?
  3. klik
    Hello, I was thinking once you start the motors if you don't advance the throttle the motors would automatically turn off after about 5 seconds. Is that not true?
  4. N017RW
    Palm Beach Co.- FL
    That is a feature found around page 10 if the NAZA-M V2 manual.
    There is a selection box in the P2 assistant s/w for immediate or intelligent shut-down.
    I'm not sure if it can actually be enabled or if the other P2 variants (V, V+) have this option in their assistant s/w as well.
    I have never tried to enable immediate shut-down for what I think are obvious reasons.
Similar Threads - Phantom motors timing Forum Date
Phantom 4 motors won't fully start Phantom 4 Help Jul 20, 2017
SOLD DJI Phantom 3 Motors Part 7 2312 Classifieds Jul 12, 2017
Phantom 3 Pro, ESC part 96? with Older 2312 Motors Pro/Adv Discussion May 11, 2017
DJI phantom 2 clockwise motors will not idle at full speed Phantom 2 Help May 10, 2017
Phantom 3 and T Motors Pro/Adv Discussion May 8, 2017
