PHANTOM 2 GOES TO FAIL SAFE BY ITSELF
I recently bought a Phantom 2, after 3 perfect flights I'm having a problem every time I try to fly it.
The Problem:
I wait for the green light and take off, but after a few seconds the lights turn to yellow, I loose the control and the Phantom goes up fast and then slowly comes down (like fail safe mode).
I appreciate any help.
Sounds like controller loosing connection with phantom. Try new batts in your controller first off.
The Problem:
bought p2 new or used one ?
if used and if modified, check antenna's connection.
if new and non modified, need to calibrate/update and follow manual/instructions.
so far you are getting lucky. dont push it. good luck !
