Phantom 2 crash, video included. What happened?
Discussion in 'Phantom 2 Help' started by Scart1, Jan 4, 2016.
  1. Scart1
    Hi you all from a long time lurker in this forum !
    I have P2 version 2.0 with Immersion Rc 600mw 5.8Ghz Video Transmitter, H3-3D gimbal and Gopro Heo 4 Black.
    It served me well for over a year until yesterday when it fell from a sky like a stone... I was lucky so he “landed” in only mound of snow on parking lot :) Few inches right or left and I would be crying now...and ordering new one ;)
    So on to the details, battery was on 95%, remote was on GPS ATT, 9 satellites locked, temperature was -5 C (23F). As you can see and hear in video, everything was steady and OK and then suddenly phantom tilted on one side and then dropped in snow upsidedown (not straight down, he fell diagonally)....
    I’m thinking, if there was sudden loss of power then why can I hear motors (or some of them) running when phantom is tilted for 2 seconds.... but then, before it hits snow I can’t hear any motor running.... also when he fell you can hear one beep (motor problem ?).
    When I picked it from the snow battery was on, no beeps indicating problems, motors off, and lights flashing normally (satellites locked, ready for take off).
    After watching video few times, I can presume:
    a) 1 or 2 motors turned off, phantom tilted and went down but i don’t understand why I can’t hear some of motors just before it crashed
    or
    b) there was total loss of power and only explanation why he didn’t fell straight down is that some of motors kept spinning second or two longer so that made him tilt before crashing
    Today I turned it on (indoor only), and everything seems OK, no warnings, propellers spinning and he is ready.
    Tomorrow I will open him and try to find something (loose wire?) but I don’t know what i should check inside...any suggestion ?
    What’s your take on this after watching video? (yes it's night time, waiting for fireworks)
    Thanks in advance !
    Damir
  2. jason
    Commerce Twp,MI
    Take that battery and fully charge it then check in the assistant software and post a screen shot of that battery. Video is just to short and dark to make judgement call as to what went wrong.
  3. Contact EZDrone
    Cold batteries decrease flight time, but this looks more like a phantom 2 software bug. All of the mechanical components on the aircraft should be extremely reliable, especially if it was just flying fine just before the crash. I have seen many phantom 2 customers with the same problem and not any phantom 3 customers. The p3 and p2 are very similar in what they do, but now DJI has all of its focus on new product.
  4. jason
    Commerce Twp,MI
    While it is true that weather decreases fight it doesn't cause them to fall out of the sky.
  5. Scart1
    Hi,
    here is the screenshot.
    Thank you, bye !
  6. jason
    Commerce Twp,MI
    If there wasn't any physical damage to the P2 remove the props put that battery in and see if the motor will spin up.also make sure all the LED's fire up as well.
  7. Scart1
    Already did that "Today I turned it on (indoor only), and everything seems OK, no warnings, propellers spinning and he is ready."
    So if battery is OK what else could be the problem ? Bad wiring maybe ?
  8. jason
    Commerce Twp,MI
    Do you have an FPV system onboard? If not keep it close you could have cold connection on one of the motors that caused it to come in the first place.
    Good Luck.
  9. Scart1
    Yes, FPV is installed. So I will open phantom today and examine all the wires and maybe find something, although I'm not sure what exactly should I look for :)
    Thank's Jason !
  10. jason
    Commerce Twp,MI
    Look for cold solder connections for the motor and the power supply from the ESC modules to the main board. So if any one of those ESC or motors has a cold connection it will cause a crash.
Similar Threads - Phantom crash video Forum Date
Standard Phantom 3 no video after crash Phantom 3 Help Jan 24, 2017
Video of DJI Phantom 3 Standard Crash Standard/4k Discussion Dec 9, 2016
4k phantom 3 crash with upset gimbal (video included) Phantom 3 Help Nov 22, 2016
No Camera/Video Capture - after Crash Phantom 3 Pro/Adv Discussion Apr 17, 2016
Crashed my Phantom 3 in Nepal mountains flying at altitudes up to 4000m, video General Discussion Dec 7, 2015
