Phantom 2 Assistant Software v3.2
P2 update; Phantom 2 Assistant Software v3.2
P2 Update; Phantom 2 Assistant Software v3.2
July 29, 2014
PHANTOM
Main Controller Firmware V3.06 released
What’s new?
1. When the battery level reaches a Critical Battery Level Warning, the aircraft will automatically land. The motors
will poweroff after landing.
2. When the battery level reaches a Low Battery Level Warning, Auto Go home will be activated.*
3. Descending speed will be automatically adjusted based on current altitude when the battery level reaches a
Critical Battery Level Warning.
4. Minimum adjustable height limit set to 20m.
5. Magnetic declination value stored to improve flight course accuracy.
6.Various bug fixes.
Phantom 2 PC Assistant
1.Added Japanese as a supported language
Note
1.To up grade main controller firmware to v3.06 or above is required.
2. Be aware that aircraft will now automatically return to the Home point on Low Battery Level Warning.
If you wish to disable the auto go home feature, launch DJI Phantom Assistant, enter “Battery Settings” section and deselect the “Go Home” option.
Pauos31
