ElGuano said:
Tobrouk said:
iOSD mini and PMU V2 is the way to go... The upgrade board has NO CAN BUS!
The Upgrade Board needs CANBus to communicate with the built in GCU. A few people here have done the Sarawuth mod to be able to access the CANBus, but you need to be fairly comfortable soldering a few small wires to the board.
For those with an H3-3D or H3-2D, the upgrade board is a much lighter solution than a PMU + GCU as well. Neither solution is plug and play, but the upgrade board helps keep weight down and flight times up.
ElGuano, I hope you see this. I was wondering if there is some list that shows the meaning of all the acronyms, I get Power Management unit, I don't GCU? And I took lots of buss's over the years, and CAN BUS was not one of them.. should be easy to google can bus naza and I see the pin out on the PMU v2 that I just put on my bird but I cannot find a sentence that tells me what can bus means and what it means to me...
There should be a list,
osd, on screen display
fpv, first person view
pmu, power management unit
lol, hahahahaa
