Phantom 1 looses signal at 50ft
My Phantom 1 looses the signal to the transmitter at a very short distance (50-100ft), everything is stock, does someone have a solution to this problem?
Checked cabels, batteries and done all calibration and updates.
How about your antennae condition (no visible cracks or looseness) - or the antennae on the P1 - broken/disconnected/loose wiring?
It looks okay, what does the little plug on the end of the antenna on the drone?
I installed the latest update from the NAZAM Assistent, is that wrong software for the P1?
I am not all that familiar with the P1 - the little plug you mention no idea.
If you have calibrated your IMU etc the only issue I can think of is antennae orientation............
I've tried that, but that "angle" should not be an issue within a 100ft radius i think?
So i need more tips!
You may need to replace the receiver board in the quad itself. You can find them on eBay . I also have a source where you can get them.
wkflysaphan4
