I have the above quad and it's still on ver 4.00. What is the 4.02 supposed to do to improve things. Mine has no problems at all so why should I upgrade? I see some have problems after upgrade and even other Phantom models too.
Monte55 said:When it hits the fence, does it keep gps position in space or will it drift? Is that the only change in 4.02? Thanks for the info.
Jebus said:I assume with 4.02 you can still control it fully to bring it back within the set limit - right? It just won't let you go any further - like hitting a virtual wall?
ElGuano said:Jebus said:I assume with 4.02 you can still control it fully to bring it back within the set limit - right? It just won't let you go any further - like hitting a virtual wall?
That's right. 4.02 fixes it, and makes it work as you'd expect it to (better than it was originally intended to work in 4.0).
