Permanent fix for gimble shaft
Has anyone come up with a permanent fix to keep the gimble shaft from slipping and causing the thing to loose its mind? I have to recentered mine about every two flights. Will super glue or something on the other end of the shaft hold it in place?
There are several videos on you tube that show them using epoxy and other fixes to look the shaft down. Do a search on phantom 2 vision plus gimbal repair and you can get some idea as to what may help.
