Painting / Spay Painting
Discussion in 'Standard/4k Discussion' started by DarkXess, Dec 18, 2015.
  1. DarkXess
    Hey all, I am wondering if you can help me, I am wanting to paint or spray paint my Phantom 3 and have been told that I need to know what material its made of before I paint it as the type of paint could damage it, I don't know if this is true so I am wanting to get clarification. If so can guys also recommend any decent paints to be able to use on drones?
    Thank you.
  2. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    Xorge and DarkXess like this.
  3. Adil J
    Mississauga, Ontario
    I would highly recommend you don't paint it. Get a decal instead. Not permanent, and has no risks.
  4. DarkXess
    Thanks for that :)
    I have tried but finding a skin (custom decal) for a Phantom 3 Standard is hard! they are all for the advanced and pro which I've found.
  5. mcphipps
    Wheatfield Indiana
    All three of the bodies are the same I think.
    DarkXess likes this.
  6. RodPad
    Pacific,NorthWet, 97031
  7. jbe420
    I want glow in the dark paint on props
  8. mikep2323
    I bought one on ebay for just phantom 3. It went on good. It just doesn't go onto the controller. There all the same body like the other guy said. You can paint the controller and put skin on phantom.
  9. DarkXess
    I was thinking maybe the bodies are the same. Anyway thanks for your help guys :)
  10. Phantom3Chris
    NYC
    Sup new to this hobby and I want to paint/dip no decals as they are ALL boring! Need to know if it affects the phantom 3 (standard) in any way? Read a bunch of stuff and maybe overloaded my brain fell as I don't have a plain and simple yes or no answer or can't find the right info I'm looking for..... Any help??
  11. N017RW
    Palm Beach Co.- FL
    The only consideration would be to avoid metallic paints/decals as this can have an attenuation effects on the GPS reception (when applied to center of top half).
  12. Phantom3Chris
    NYC
    Nice perfect answer looking to do matte colors (military theme) so hoping I get same performance.. As far as hydro-dipping should steer clear same properties??
  13. N017RW
    Palm Beach Co.- FL
    Yep.
    Avoid metals, foils, etc.
    Consider the added weight
    Process compatible with plastic
    Otherwise it's like any other model you may have painted before.
    EDIT: Same for landing legs as they contain the control & video antennas and compass.
  14. Phantom3Chris
    NYC
    I am thinking weight that's why I'm considering the hydro dip(expensive) method! Any links on weight issues after paint? Losing a min or two on flight not a problem as I have second battery.
  15. N017RW
    Palm Beach Co.- FL
    Don't be overly concerned with weigh from customizing, just be aware.
    I've used paint cause it's easy, cheap, and I know what to expect from me as far as results go.
  16. Phantom3Chris
    NYC
    Every hobby (plastic) I do the usual sand,light coat,med coat,finish light/uneven areas.. Good routine for aero hobby?
  17. Phantom3Chris
    NYC
    Forgot to mention (already installed) pro guard, polar pro landing kit, carbon fiber -gimble guard, propellers
  18. N017RW
    Palm Beach Co.- FL
    Yea, just plastic(s) so go with what you know!
    Be sure to show-off when done.
  19. Phantom3Chris
    NYC
    Sure will this will be this weekends project. Def will post a pic thanks very helpful!!
  20. Phantom3Chris
    NYC
    Finished product!! Gonna add decals this tho!!
Similar Threads - Painting Spay Painting Forum Date
Light painting with P4 against Milky Way Photos and Video Jun 12, 2017
Painting Rotor Blades? General Discussion Jan 22, 2017
Painting the P3 professional landing gear is removal hard? Pro/Adv Discussion Jan 11, 2017
Painting Phantom 3 Pro/Adv Discussion Dec 9, 2016
Free, open-source flight app (iOS) for light painting in beta! General Discussion Dec 1, 2016
