P4P best shutter speed for video?
Hi guys, On the P4P and with the ability to adjust the aperature , what is the best shutter speed to aim for, to keep the video crisp but still allowing fluid looking motion.
Twice the frane date. You will probably still need ND filters in bright conditions (midday sun you will be around TV of 1/200s @ f11). Also bear in mind that apertures smaller than f5.6 diffraction effects will limit apparent sharpness.
Ok thanks, much appreciated. I generally try shoot at 50 FPS with the drone because of the general fast motion of drones. It was a sunny day when I did a test. I had the aperature at f9 to try slow the shutter a bit, I didnt see the shutter speed again when I was flying. But when I do a pan the video image tends to blur a bit which I dont get with my P4. Its very little blur but as the pan stops you can see small detail a lot better. It may also just be my laptop refresh rate as its 4k @ 50FPS whereas my P4 can only shoot 2k @ 50FPS.
Spicehub
