After seeing some P4 videos it appears the extreme angles of attack in S mode are going to be problematic to keep the props out of the video. With P3 I can pitch the camera down about 15 degrees so the horizon barely shows and you didn't have to worry about props getting in the video so much. This pitch trick would eliminate about 95% of the problem. However with P4 it appears the controls are very sensitive in S mode, and the 15 degree pitch down trick isn't enough to solve the problem, given the sensitivity in S mode and angle of attack capability. Using P mode in the P4 appears to be the only way to mitigate the problem, however that's limited to 22mph, 30% slower than P3. That's a problem that may need to be solved. With P3 I can generally do 32mph with the horizon barely showing without props in the view. To do that reliably with P4 is going to be difficult I think. What are you guys finding out on this subject?
