The p4 is supposed to have a better lens than the p3 and other than that, basically the same.
Anyone know of any side by side comparisons posted ?
Basically it fixes all the blurry mistakes that were in many lens that came with the P3P. Some P3P had perfect lens, but I've had two that had major blurring around the edges. New lens should prevent that.
Have you seen the images and video that Ken(blade strike) and Ed posted? The quality is a huge step up from than the quality I was getting with my p3p. I have some raw video that Ken shared with me taken in log mode if you want to see it. Looks very close to my x3 footage.
Where are those images and videos?Have you seen the images and video that Ken(blade strike) and Ed posted?
If it was misalignment of the sensor the whole image would have been out of focus, I went through 6 Phantom 3 Pros and all had different spots on the lense that wouldn't focus. I eventually sent the 6th one in to DJI and they replaced the camera and gimbal but then I had gimbal problems again so I just returned it to bestbuy for in store credit.I think those instances were cased by the misalignment of the lens on the sensor. Not necessarily a bad lens.
Am I seeing correctly. It looked like one camera was sharp around the edges and the other camera was sharp from mid video on down.here is a video I shot with the p3p and inspire.(default settings on both with nd8 on both) You can clearly tell which are higher and lower quality.
Even though it appears an ND filter was used, it is apparent that the Phantom 4 still suffers from the same noise issue as the Phantom 3... check out the sky, just plenty of noise.Have you seen the images and video that Ken(blade strike) and Ed posted? The quality is a huge step up from than the quality I was getting with my p3p. I have some raw video that Ken shared with me taken in log mode if you want to see it. Looks very close to my x3 footage.
I'd say about 50% of all the P3 have blurry lens issues. Some worse than others. I've replaced 4 camera and all but one and the blur. The one that was perfect made photos easily that good. I think people all have blurry lens and don't realize it's a defect. I didn't know it was a defect on mine until I replaced the camera for another reason.
