  1. Moonie
    Has anyone done a range test? I'd like to know the results.
  2. KyleMaxxUAV
    Approved Vendor
    I'm guessing very similar to the p3 lightbridge models / inspire / Matrice 100 .... Regardless I think I'm going to be doing a long range antenna setup.. Now which one is the question !!
  3. Moonie
    I'm hoping so.
  4. JakeMaxxUAV
    Approved Vendor
    Stock range I was able to get 5132 feet. I'm in a crowded wifi area. I then installed an ItElite Antenna and two Sunhan boosters and got 11386 feet. Could have went further but had a strong headwind on the return flight, so I wanted to make sure I'd make it back haha! But landed with 40% battery life left.
    Santiego likes this.
  5. KyleMaxxUAV
    Approved Vendor
    The p4 uses the same lightbridge as the p3p&a, inspire so range will be very similar for sure
  6. Moonie
  7. AlexanderAF
    6212.5 feet. Still had good control but didn't want to stretch my luck.
  8. nhoover
    Los Gatos, California
    I have to say I was not impressed with the range. Back in 1.1.9 days with P3P, I had 5 bars at 4.01 miles at low altitude with just a little windsurfer (Taco RC). Lately on the 1.6 firmware it's not as good but I can still go over 3 miles at a good quiet location.
    With the P4, it was stuttering and having trouble between 2000'-3000' with no windsurfer. With the windsurfer I went to just over 6000' but lost signal bad enough to trigger RTH briefly. I've flown my P3 at the same place a ton of times and it never glitches - even at double that distance.
    The P4 was without the 32 channel hack, on the 4Mbps quality setting. I'll play around with it some more but my first impression is that it is no where near as good as the P3P. :-(
    GadgetGuy likes this.
  9. Moonie
    I'd like to see your total distance on that flight.
  10. Kman
    San Francisco, CA
    Do you have an early P3P like me with the Version A controller? If so the output is roughly 30% stronger compared to the later version P3P's and P4.
  11. nhoover
    Yes I meant to say that I have the original P3P controller. Wonder what would happen if I rebound it to my P4! That might be the way.
  12. John Locke
    Yorba Linda, CA
    I'm worried, my P4 didn't perform nearly as well today as my P3 from the same location, with or without windsurfer. Without windsurfer it started crapping out at around 2000, and with WS at about 3000. I get twice that with P3 in this particular suburb area. I'll be trying shorelines next where I usually get over 10,000 with my P3 using windsurfer. I think everyone who expects P4 to perform like P3 for distance is going to be disappointed, I hope I'm wrong. I'll be interested to hear more results from others.
    #12 John Locke, Mar 18, 2016
  13. nhoover
  14. m0j0
    Very strange maybe they tuned it down.
  15. Toph
    Phoenix
    That is strange. You'd think at a minimum it would have the same transmitter hardware as P3P, if not better. I can't imagine them deliberately tuning it down for any reason.
  16. m0j0
    I was thinking it would go farther
  17. John Locke
    Yorba Linda, CA
    For video is the power of the bird's Lightbridge sending the video signal to the ground has the greatest affect on achieving long distance, more than the RC receiving it. The RC transmission power helps to control the craft longer distances.
    Yeager74 likes this.
  18. John Locke
    Yorba Linda, CA
    In your case, it appears you're in the desert and the craft was 1600' high on top of a mountain when you got 6000'. Was that without windsurfer, and a stock antenna?
  19. Dirty Bird
    Glen Burnie, MD - USA
    I plan on heading out early AM (weather permitting) with 3 birds. Long range P4 testing is one of the missions.
  20. AlexanderAF
    I'm doing s range test for a Digital Trends review. Had no trouble until it left my line of sight. 8,895 feet.
Similar Threads - Range Forum Date
Crash, replace Yaw Motor..and strange issue Phantom 4 Pro Help Yesterday at 8:36 PM
Any one in north Orange county CA area? That can help me activate my P3P?? Pro/Adv Discussion Yesterday at 2:44 PM
Strange gimble/camera reaction to loading camera settings Phantom 4 Pro Discussion Saturday at 8:23 AM
Range Issues General Discussion Saturday at 7:08 AM
Why does the Spark have more range then the P3S if they both use wifi? Standard Thursday at 4:30 PM
