D
Deleted member 62848
Guest
Has anyone notice that after update p4 now records sound I clip a video and try upload
Not switch it just happen .can't upload says error so I try utube..I update shortlyInteresting. Is there a setting you need to switch on? I shot some footage yesterday and there was no audio.
OK short clip I just put on somewhere hereNot switch it just happen .can't upload says error so I try utube..I update shortly
That's not the p4 recording, but the Go app. It's using the microphone on your tablet/phone to record with the lower resolution video that the app receives and records. Useful, but not the same as on-aircraft recording. Firmware update wouldn't magically create a microphone on the AC!
Has anyone noticed when reviewing videos in dji go editor while this option is enabled, there is a weird blurr out effect that occurs during the last few seconds of the video? Sound would still be playing but the video is not viewable. I haven't tried it again to see if it was a glitch but it definitely happened the first time I used this feature.Yes, this is useful... I frequently will make "notations" or comments throughout the flight... I normally do this using the AZ Screen Recorder app....
P4 sound will record the sound of your propellers lol and probably nothing else
I can see if you are doing live streaming on a budget. I found it wasn't bad the few videos of mine I watched. Not broadcast quality but not as bad as you would think.Ok why would you want to record the sound at your takeoff point? Surely better to do any voice overs in a sound controlled environment
