P4 flight stability issues (v P3)
I've been flying a P3P for a few months now, and just got a P4 and finding that it's not nearly as stable in flight as the P3 is in the same conditions.
For example, normal take-off / hover without touching the sticks results in very noticeable change in height and position; it doesn't hover in place as the P3 does reasonably well. It drifts higher/lower as well as laterally. This is generally true throughout flight. For example, if I lock a course and fly fwd/back the P4 drifts off course ends up in a very different location on return than on the fly out. The P3, although not 100% precise, flies the same locked course out and back gives me a fairly straight line and returns to the same point.
This is all while flying the P4 and P3 in the same location at roughly the same time; one, then the other.
Any thoughts on troubleshooting / remedying this?
All of the firmware updates have been applied, compass calibrated, strong GPS signal (18 satellites).
Thanks.
Did you try calibrating the IMU on a level surface too?
A bad IMU calibration can cause instability and even a crash. Always check sensor values before take off, overtime IMU can also become uncalibrated, and might need new calibration if not in the proper range.
Reactions: Sim597
Is or are there some actual values or numbers you could tell me to watch for when looking at that it looks Chinese. I'm not Einstein but I'm not a complete fool, if you could tell me or us it would be much appreciated!
I can see those numbers and always wish I could make some sense outta them or tell if it looked cranky.
Reactions: isopro
the Gyroscope MOD reading should be near 0, and the Acceleration MOD reading should be right around 1.0, Compass MOD 1400-1600, if they are not really close to those range, it require an IMU calibration.
Mine too.
Thanks for this great info. Quick question - when I look at this sensor data with the Phantom parked on a flat service with no vibrations the numbers kinda bounce around a bit. Is this normal for the data to fluctuate a bit but to be near the numbers you mention? TIA
wkflysaphan4
