Standard P3S range near power lines
Discussion in 'Phantom 3 Help' started by longdog, Jul 2, 2016.
  1. longdog
    so I just installed the ITELITE DBS antenna on my P3S. I had my first flight ever here by my house and got about 1200 feet then RTH kicked in. I'm in a populated suburban area outside of NYC. Lots of wifi signals around and I flew to about where the huge main high power lines run for the area. I figured that could be an issue.
    Question is, how bad to high power lines mess with these things? I assume in a clear area with better line of sight and less houses and no near power lines of get better range, but any ideas how much? Or how bad I'm getting impeded by the power lines?
  2. knipfer
    Flying near high voltage power lines will cause some interference. 1200ft doesn't sound terrible especially right out of NYC. Test in an open area and I'm sure you will get 3,000' + easily
    longdog likes this.
  3. longdog
    Yea sounds about in line with my expectations. I'd like to see more than 3k feet with the DBS. Maybe I need to add boost/amp?
  4. Jason Porembski
    I'm on Long Island and in normal residential that's pretty. I have what I get. Maybe 2-2500 feet. At the beach I got 1.25 miles with a stock P3S.
    longdog likes this.
  5. knipfer
    I have a DBS antenna without boosters and always easily get 2,000+ keep in mind the antenna is REALLY directional.
    Pharm likes this.
  6. longdog
    I was out tonight getting some shots of fireworks in the distance and did a little bit of a distance run, made 1360ft; video signal started to get choppy so I headed back. On the way back while cruising around, my signal "Disconnected". I saw no information on the screen, just grey. Thankfully the P3S was in line of site so I started to come in and lower at which my signal came back thankfully.
    I am definitely learning that the DBS is very directional. I think I have got to play around with it some more.
    I know I am in a less than ideal area for signal. I am flying out from a townhouse development between tall buildings and trees with the high power lines about 1/2 mile away. Tons of wifi around me too and I had issues calibrating outside my home. Seemed I had magnetic interference. Bus ben from rebar under the development.
Similar Threads - P3S range near Forum Date
DJI P3S Mod TX Power 27dBm + DIY Windsurfer Range Test at Residence Area. General Discussion Jul 19, 2017
P3S range and video issues solved...at least for me Standard/4k Discussion Jul 9, 2017
Standard Reason Why Stock P3S Has Such Poor Range Phantom 3 Help Jun 15, 2017
P3S Range Tanking! - Time to be Concerned? Standard/4k Discussion May 27, 2017
P3S Range Question Standard/4k Discussion May 11, 2017
