P3s Firmware Upgrade Error
Hi Guys and Girls.
Having an issue regarding upgrade. Downloaded the upgrade then tried to install on my machine. The following happened.
1st attempt. Upgrade went to 40% then stopped(upgrade failed message. Server traffic etc)
2nd attempt. Switched on machine and got a loud bleeping noise and only movement from 1 of the rear rotors.
Any advice appreciated.
Cheers. Mark.
Let the loud beeping noise continue. The firmware should eventually finish installing. If it does not, format the memory card and try going through the entire upgrade process again.
