Some don't realize you can instill the DBS without drilling any holes, but you can't use the cables that come in the kit. You'll need to get longer ones that go from the RC board right to the DBS, no contention on the remote itself. And cables don't cost too much. I drilled mine, it's not a big deal to drill three holes in a piece of plastic.Argek flat panels are really the best unless you want to drill holes in it and put the dbs mod in which isn't much, if you are willing to spend a couple hundred dollars, either buy the lightbridge kit for like $1000 for ultimate range or upgrade to a phantom 4, but the argek antenna is the best, also if you aren't getting the range you were looking for with the argtek fiddle with the antennas for where they are facing, you can get up to an extra 1000 feet from adjusting thise
i was thinking of trying this out
Enhanced FPV Distance 5.8GHz 14dBi Panel 3dBi Antenna for JJRC H25G H29G RC395 | eBay
Agree, the DBS isn't much better than the Argtek, it's a lot better. IMO I'm pushing 4600 meters with my DBS, and that was only because my battery was getting low and I turned back. Not sure how far it would have gone if I wanted to do a suicide mission concerning the battery limitation. Don't get me wrong, the Argtek is much better than stock when it's working. But not everyone is impress with it's range, unlike the DBS where almost everyone is very please with the improvement.I understand, but if you want it to be installed properly and look correctly you will, plus the dbs isn't much better if any than the argtek
Everything in your post is wrong.I understand, but if you want it to be installed properly and look correctly you will, plus the dbs isn't much better if any than the argtek
