Standard P3S 1.6.80 FW update as of 29 Aug 2016
Discussion in 'Phantom 3 Help' started by greg manchester, Aug 29, 2016.
Tags:
  1. greg manchester
    I just wanted to get this on here to see if anyone else has received the FW update 1.6.80 today ?
    After months of waiting for a fix for the range issue, is this the update that will solve it ?
    I'll charge up & get it out for a fly today & post results but has anyone else got & tried this FW & what's the verdict?
  2. PapaTita
    Strange, the new version should be 1.7.xx
    1.6.8 not recommended for upgrade
    Sent from my Redmi Note 2 using PhantomPilots mobile app
    lafester likes this.
  3. greg manchester
    1.7.xx is what I thought to be rolling out end of August too but you can see from the screen grab it's 1.6.80
    The current FW on my P3S is the P3C_FW_V01.07.0082 downloaded from one of the other threads & there has been no upgrade options on the DJi app for months until today.
    The saga continues...................
  4. greg manchester
    Well.. I am unhappy to report that whatever that update was, it did zero to the usability of the P3S & it's lack of range. After the update, it wanted the IMU calibrated & seemed to have an issue with the compass. Saying it had interference too close, I found a spot where there was no issue. I checked everything & calibrated & took off. Less than 50 feet in the air, the signal was already lost & I brought it down. [Bringing it down was iffy. It seemed to hang in the air with no response from the controller]
    As far as I am aware, the compass has no damage & would not add to the loss of range issue we have experienced.
    I guess there is no other option than to send it in for a check & repair or to sell it.
  5. AustrianOak82
    Subbed, I was also thinking it would be a different number. I went to 1.5.7 with no changes. Patiently waiting...
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  6. phantomlee
    Hi guys,just recieved my p3 standard today..
    Now ive been reading about range issues and firmware issues and i must say im scared to even power on my drone!
    Is this issue with every drone thats been updated? Ive seen ppl on youtube saying not to download the latest firmware? Im still unfamiliar with the whole updating process as im still learning abt the drone
    What should i do / not do?
    Tia
  7. rocketflyer
    Read manual thoroughly, power it up, check everything works, set up app (ignore any app request to upgrade firmware), calibrate, test flight.
    Not everyone has issues - plenty of videos and posts from happy owners with no range problems.
    ghook73 likes this.
Similar Threads - P3S update Aug Forum Date
Should I Update The P3S Firmware? Standard Nov 4, 2017
P3S/A/4k/adv updated DJI GO IOS version numbers for use w Charles proxy Standard Oct 20, 2017
P3S communication problem after update Standard Sep 12, 2017
P3S Flight Restrictions After Firmware Update Standard Sep 4, 2017
P3S update failing at 0% Phantom 3 Help Aug 16, 2017
