P3P Landing Pad Ideas
Discussion in 'Pro/Adv Discussion' started by PinesPhantom3, Sep 20, 2015.
  1. PinesPhantom3
    I've been looking for a few days to buy a landing pad for my P3P but couldn't find anything that looked strong enough... Finally decided to make this 2 x 2 ft landing pad with some thin wood and bought two bottles of spray paint. I'm considering adding four 2-3 in legs to raise it a little from the grass. I just made it after reading all the complaints about people flipping on the grass. Would like to hear your ideas or suggestions.
  2. RedHotPoker
    Edmonton Alberta
    Looks good as is. Why complicate it, with feet, legs or stands?
    Easier to store flat anyway. ;-)
    Fine job.
    RedHotPoker
  3. IND2RVA
    I've never had any issues hand catching... Let it hover 6 feet above the ground 6 feet in front of you and walk under it. Pretty easy for me.
    lotusteve likes this.
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Nice work!
    While the UAV-BITS landing pad is not inexpensive, it's probably the best available for those who don't want to build one.
    #4 msinger, Sep 20, 2015
    GoodnNuff likes this.
  5. coker
    I have found a few things that would work have not put to test the heaviest
    Being a 30 x 30 piece of granite to be left as a permanent landing pad but I believe the best ideal is starboard it's used in boating generally 1/2 thick and light weight can be bought on Internet or boating supplies like west marine but I am open to all suggestions. I bought one from a vendor that was way to small for a high price the phantom would work but no way the inspire 1 would.
  6. coker
    Well I have one of the uav bits pad I'll send to anyone who will pay shipping. Too expensive & to small a waist of money but like I said free if you pay shipping I'm tired of it hanging on wall.
  7. GoodnNuff
    Washington State
    Yup, that is the pad I have. I like it. It is light, and small enough to make transportation easy, but large enough to do the job. There are times I fly from fairly steep slopes, so I take my tripod and use the center hole on the landing pad to mount it on the tripod, enabling me to have a level launching pad regardless of where I am at.
    eBird, wolfweb and Oso like this.
  8. GoodnNuff
    Washington State
    Yeah, they are a bit pricey, but man, you are offering people a deal on that!
  9. THG Aviation
    Bedford Hills and Pine Hill, NY
    Check out my earlier posts and pictures of the pad i made. It too was 2 by 2 but you have to be careful that it's heavy enough so that the prop wash doesn't move it around. I used a birch veneer plywood.
  10. N017RW
    Palm Beach Co.- FL
    Caution:
    Granite is known to be magnetic or have magnetic properties.
    YMMV
    littlesister36 likes this.
  11. coker
    Well you learn something every day had no ideal granite is magnetic but that is strange I have flown near enchanted rock close to Austin that I believe is the second largest solid granite formation in the USA with no problems.
  12. bobmyers
    San Antonio, TX
    Maybe not all granite??
  13. Wibble
    Brecon Beacons Wales UK
    Hand Catch every time!
    Seriously it is the best and safest method!
    That would make a GREAT takeoff platform though so not a waste of time!!!
  14. coker
  15. coker
  16. bobmyers
    San Antonio, TX
    Looks great-- forget the legs, if you happed to land on the edge, it will topple and get a prop.:( Been there and done that. :D:D
  17. coker
    This forum is good makes the mind start thinking.
    Might take the pos I bought and make a bigger plate under it mounted on a 5 1/2 ft
    Pole with a slip collar in ground to slide into when flying.
  18. coker
    It does have that pretty yellow circle on it.
  19. coker
    DJI_0002.MOV
    If this works it's a video of the ranch with a large granite rock I flew around
  20. coker
Similar Threads - P3P Landing Pad Forum Date
P3P snaps pictures on landing ? Pro/Adv Discussion Jan 4, 2017
Smooth Landing (my) P3S vs P3P Pro/Adv Discussion May 30, 2016
Landing - grabbing P3P out of the air Pro/Adv Discussion Mar 6, 2016
P3p entered landing mode on its own. Pro/Adv Discussion Mar 2, 2016
P3P 4k .. Camera sees landing gear Pro/Adv Discussion Feb 26, 2016
