P3P failed upgrade help with log
Can someone decipher this log? this unit has a new main board and new camera. I get a no transmission signal error and no video when I start it and can't get it to upgrade.
[00014674]========== remo-con disconnect. boot(15) ============
[00014731]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa5733403].
[00014779]Packet upgrade start...
[00014835]Packet checking...
[00014890]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014943]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00014995]Done.
[00015051]Version checking[1]...
[00015131][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015211][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015269][04 00][00] v1.44.0.0 -> v1.48.0.0 need upgrade.
[00015391][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015531][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015580][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015679][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015780][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015880][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015980][12 03][00] v1.11.0.0 -> v1.11.0.0
[00024811][15 00][00] device not detected.
[00024916][17 00][00] v1.1.1.7 -> v1.1.1.7
[00025067][17 01][00] v1.0.2.7 -> v1.0.2.7
[00025130][19 00][00] v1.0.8.96 -> v1.0.8.96
[00025183][01 00][00] v1.30.5036 -> v1.32.5432 need upgrade
[00025240][01 01][00] v1.30.5036 -> v1.32.5432 need upgrade
[00025393][08 00][00] v0.13.0.7 -> v0.13.0.7
[00025471][09 00][00] v3.0.0.10 -> v3.0.0.10
[00025524]Done.
[00027583]Waiting for user confirm...
[00037636]Timeout, start upgrade automatically.
[00037741]Firmware upgrading[1]...
[00051120][01 00] Firmware upgrade start...
[00014145][01 00] Firmware upgrade finished successfully.
[00014208]Done.
[00014264]Packet [C:\P3X_FW_V01.10.0090.bin] resumed, card sn [0xa5733403].
[00014330]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014381]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00014438]Version checking[2]...
[00014547][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014647][03 06][00] v2.4.20.28 -> v2.4.20.28
[00014714][04 00][00] v1.44.0.0 -> v1.48.0.0 need upgrade.
[00014847][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015089][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015147][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015268][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015353][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015457][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015557][12 03][00] v1.11.0.0 -> v1.11.0.0
[00024536][15 00][00] device not detected.
[00024635][17 00][00] v1.1.1.7 -> v1.1.1.7
[00024772][17 01][00] v1.0.2.7 -> v1.0.2.7
[00024847][19 00][00] v1.0.8.96 -> v1.0.8.96
[00024902][01 00][05] v1.32.5432 -> v1.32.5432
[00024960][01 01][00] v1.30.5036 -> v1.32.5432 need upgrade
[00035036][08 00][00] v0.13.0.7 -> v0.13.0.7
[00035108][09 00][00] v3.0.0.10 -> v3.0.0.10
[00035163]Done.
[00035222]Firmware upgrading[2]...
[00035385][01 01] Firmware upgrade start...
[00065664][01 01] Firmware upgrade finished successfully.
[00065753][04 00] Firmware upgrade start...
[00125507][04 00] Firmware upgrade finished successfully.
[00125558]Done.
[00125618]Version checking[3]...
[00125710][03 05][00] v34.2.0.9 -> v34.2.0.9
[00125809][03 06][00] v2.4.20.28 -> v2.4.20.28
[00125867][04 00][05] v1.48.0.0 -> v1.48.0.0
[00126016][11 00][00] v1.8.0.0 -> v1.8.0.0
[00126150][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00126295][11 01][00] v1.8.0.0 -> v2.0.0.33
[00126399][12 00][00] v1.11.0.0 -> v1.11.0.0
[00126499][12 01][00] v1.11.0.0 -> v1.11.0.0
[00126604][12 02][00] v1.11.0.0 -> v1.11.0.0
[00126705][12 03][00] v1.11.0.0 -> v1.11.0.0
[00131460][15 00][00] device not detected.
[00131559][17 00][00] v1.1.1.7 -> v1.1.1.7
[00131700][17 01][00] v1.0.2.7 -> v1.0.2.7
[00131781][19 00][00] v1.0.8.96 -> v1.0.8.96
[00131834][01 00][05] v1.32.5432 -> v1.32.5432
[00131890][01 01][05] v1.32.5432 -> v1.32.5432
[00131968][08 00][00] v0.13.0.7 -> v0.13.0.7
[00132035][09 00][00] v3.0.0.10 -> v3.0.0.10
[00132094]Packet upgrade failed at version checking.
[00014995]Done.
[00025524]Done.
[00014208]Done.
[00035163]Done.
[00125558]Done.
Seeing 15 - device not detected would prompt me to first check the cables from the gimbal main board.
You may also have a burned out transmitter from when you plugged in the incompatible P34K camera to your P3P.
Reactions: JoBe
Yah not my best day. ok, do you mean the receiver module? I've tested the cables they are fine
Yeah. I'm pretty sure that 15 is the TX in the lightbridge module. I'm not certain though. Your post reminded me if this thread which is why I first thought cables and then transmitter.
The module arrived today, had it replaced in a few minutes and I'm back up and working again. Thanks again Oso
Spicehub
