Sorry if this is a dumb question, will a P3A remote work on a P3S bird?
Thanks.
Thanks.
ThanksNo it will not the circuit board on the standard is completely different from the board on the adv/pro
Thanks.
so the p34k control has all the camera buttons and the toggle that will function for the standard?It will not because the P3 Pro/Advanced use Lightbridge instead of the Standard's hybrid 5.8 Ghz control/2.4 Ghz Wi-Fi FPV system.
The good news is you CAN get a P34K controller & it WILL work with your Standard. The P34K controller is virtually identical in appearance & functionality to the one included with the Pro/Advanced. Internally it uses the dual-band hybrid system of the Standard.
What can I get out of the P34K controller to use with my Standard? What are it's features? Better than the standard's? Thanks.It will not because the P3 Pro/Advanced use Lightbridge instead of the Standard's hybrid 5.8 Ghz control/2.4 Ghz Wi-Fi FPV system.
thanks.You get the style of the P3 Pro/Advanced controller with all of the extra buttons & bells & whistles. If I recall correctly its specs state it is a bit more powerful than the Standard controller. I don't see the P34K controller listed as a standalone component on DJI yet so you'd have to check for someone selling once from a lost or crashed P34K.
