P3a no signal twice today
Discussion in 'Pro/Adv Discussion' started by dllcm, Aug 26, 2016.
  1. dllcm
    This was the first day it has happened to me, both times I had no signal but was able to return home and once in sit I was controlling it and landed. The first time I didnt do anything but go home and charge. The second time I powered off my ps3 and turned it back on and it connected. Before I powered off I looked around in settings under the controller section and noticed lots of red spikes and drops on the different channels it was showing. My firmware is up to date, what should I check?
  2. With The Birds
    Australia
    You flying a standard or advanced (title suggests A your post says S)?
    Either way signal loss varies a lot with where and how you are flying. Try somewhere away from interference and obstructions and see how you go.
  3. flyNfrank
    Indy, USA
    If it's a P3S.....your in the wrong forum. This is the Professional and Advanced forum.
  4. dllcm
    Advanced, I am thinking it must be some interference in the areas I was flying since I have flown it a bunch and it only happened those two times
Similar Threads - P3a signal twice Forum Date
Airdata - signal strength score 0 / P3A Flight Data Analysis May 13, 2017
New P3A - Opinion on signal quality Pro/Adv Discussion Sep 21, 2016
P3A Weak Signal on Startup Pro/Adv Discussion Jul 2, 2016
Advanced No Signal - P3A thinks its P3Pand possible firmware issue Phantom 3 Help Jun 23, 2016
P3A SIGNAL LOST at 1500m for 1m21s but RTH not initiated? Pro/Adv Discussion May 17, 2016
