P3A Miscellaneous Questions
Discussion in 'Pro/Adv Discussion' started by RamiAgonistes, Feb 23, 2016.
  1. RamiAgonistes
    Hey guys. I previously had a P3A and sold it and just now ordered another P3A because I missed it too much.
    Anyway, my two main questions are as follows:
    1. Interested in the DJI black carbon fiber propellers. I like the look of them but want to know if they will make a positive performance enhancement. What are the pros or cons.
    2. I see lots of talk about filters. My first time around I never used one nor did I ever consider it. However, now I'm curious. I'm just an amateur flyer and don't use it for any kind of business purpose. Is it worthwhile to buy one? If so what's a good brand that easy to use?
  2. exit 4
    Southern New Jersey
    I'm far from an old pro. I have both carbon fiber and regular stock props. I have every flight time and all stats documented and can see no difference in prop performance. They seem to sound a bit different but nothing other than that. As for filters, I can see a difference in my pics and videos. Definitely worth it to have filters if you plan on doing anything with the pics/video. Bottom line, save the money on the props and spend it on the filters. Good luck.
  3. RamiAgonistes
    Thanks exit. What filter are you using? I'll probably try the one you have
  4. exit 4
    Southern New Jersey
    I have a set from Taco rc. It has nd 4,8,16,and 32. I also plan on getting the 64 when it comes in stock. You will see the difference in quality as soon as you use one. Do a search and you will find a list of which filter to use in which sunlight. Worth it to learn and use them.
  5. JickMagger
    I think one of the cons of carbon fiber propellers is if the props encounter a person they will cut them more easily. Also I hear when they break they shatter into shards.
  6. exit 4
    Southern New Jersey
    I've heard that too. They look cool, that's about all they are worth.
  7. robinb
    I did the same re selling and buying.
    I need to get another ND filter, helps with brighter days to tone it down a bit.
  8. RamiAgonistes
    I don't want to do a whole lot swapping of the filter. Having said that what would be the best # ND filter for all occasions?
  9. Imabiggles
    If they were full CF, yes as CF tends to shatter. The DJI's are not full CF, just CF reinforced. Flex less therefore sound different. PERHAPS a bit more responsive and nimble, however I dont need a AP platform nimble so they offer no advantages to me other than looking cool.
    B
  10. robinb
    I found the ND4 quite good in bright sun.
    Liked it.
Similar Threads - P3A Miscellaneous Questions Forum Date
[P3A]Chiesino di Cavagliano (small church), Tuscany Italy Photos and Video Yesterday at 2:23 AM
Newest update not taking with P3A Pro/Adv Discussion Sunday at 9:23 PM
P3A RC Cyan led fix and I can't enter in camera view Pro/Adv Discussion Sunday at 12:10 PM
P3A, Follow me stops working Pro/Adv Discussion Jan 3, 2018
[P3A] Torre mozza, Tuscany italy (sea) Photos and Video Jan 2, 2018
