- Joined
- Oct 29, 2015
- Messages
- 3
- Reaction score
- 0
- Age
- 54
Hi, is that normal the RC signal lower than the video feed back signal? I lost my RC signal in around 800m from me.
This is not normal. Pls check for interference on the chanel you are on and preferably do the 32ch hack. Also make sure your antennas are vertical and in parallel with the bird's landing gears.Hi, is that normal the RC signal lower than the video feed back signal? I lost my RC signal in around 800m from me.
Don't do the 32 channel hack - you aren't there yet. It MAY be normal depending on what is between you and the Phantom. Trees / buildings / giant monsters / power lines will all degrade the signal. 800 meters is pretty good for my if I am trying to talk to the bird through 200 foot Sitka Spruce trees. Open line of sight, not so much.This is not normal. Pls check for interference on the chanel you are on and preferably do the 32ch hack. Also make sure your antennas are vertical and in parallel with the bird's landing gears.
Your RC chareged at 50% min.
