P3 Firmware P3A firmware faild solid red light on.
kii
My drone crashed.
I changed ESC board.
On DJI GO, it says update required. It doesn't detect battery. Other than that, everything is ok.
I put bin file in SD card but after a while solid red light keeps on.
I formatted SD card and tried 3 times and changed to other SD card but same thing happens.
Please tell me how to do.
Delete history success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.12.02 12:24:59 =====================
Packet: P3S_FW_V01.10.0090.bin
Result: Abort.
========== 2016.12.02 12:25:34 =====================
Result: Abort.
========== 2016.12.03 13:19:15 =====================
Result: Abort.
========== 2016.12.03 15:13:13 =====================
Result: Abort.
========== 2016.12.03 15:17:09 =====================
Result: Abort.
========== 2016.12.03 15:19:08 =====================
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Failed.
========== 2014.01.01 00:00:10 remo-con disconnect======
Result: Failed.
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:09 remo-con disconnect======
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
========== 2017.01.13 01:24:03 =====================
wkflysaphan4
