P3a crash , GIMBAL FOUND.. going to keep for now
FOUND USED GIMBAL SO GOING TO USE IT A LITTLE LONGER...
Well I got it stuck in top of tree and had to cut tree to get it. Gimbal is messed up. Body is cracked in a few spots. Turns on but has message about gimbal and gps.
I just reluctantly ordered a new one caus I was having too much fun. Almost went with inspire but since I had batts and charger figured I'd stick with advance.
Make offer on 3a and controller. I will consider throwing In battery and charger but would like to use with new one. I have box.
Found used camera, so I'm going to keep for now...
Motors fired up for take off so might be fixable with a new gimbal
That sucks.
I see why you crashed. There are 4 anti-drop pins installed on your gimbal. You only need 2 installed diagonally.. :)
On a serious note, It looks like the Yaw arm is bent from the top shaft and it isn't able to move correctly to initialise.
I took gimbal off last night, looks like it will fly, will try later. Controller otta be worth more than what I'm getting offered. I may just let my kid have some fun with it and buy new gimbal for 260
hirehackers
