P3 Weatherproof Hardcase - under $40
Discussion in 'Pro/Adv Discussion' started by tcope, Sep 12, 2015.
  1. tcope
    Salt Lake City, UT
    22" Black Tactical Weatherproof Equipment Case
    • Built-in O-ring with secure latches prevent water and moisture damage to contents
    • Padlock compatible for additional security
    • Built-in pressure relief valve
    • High-density ABS polymer provides outstanding strength and corrosion resistance
    • External dimensions (L x W x H): 22 1/2 " x 16 1/2" x 8 1/2"
    • Approximate internal Dimensions (L x W x H): 19 1/2" x 13 1/2" x 8"
    $46.99 - $17.00 (code A509) + $7.99 shipping = $37.98 to your door.
    #1 tcope, Sep 12, 2015
  2. DJi Newbie
    Ship to israel?
  3. tcope
    Salt Lake City, UT
  4. DJi Newbie
    its not clear if the case includes the foam insert cut to phantom 3 size, and no pics of the P3 in it
  5. tcope
    Salt Lake City, UT
    The foam is not cut at all. It's pick and pull foam so you cut it out as needed.
  6. Cerone
    San Diego, CA
    I have this case for my p1. It's awesome. But to clarify the foam is only pick and pluck on one of the 3 layers. The others you need to cut with a razor.
  7. Stile2112
    Union City, California
    When the pick and pull foam starts to break down and fall apart... and it will, you'll get nice tiny foam pieces inside your motors. I'm sure that won't hurt the motors.
    Hope $40 is worth it.
  8. MikeON
    Pennsylvania, USA
    A P3 would be a pretty tight fit height-wise in that case. I had my P2V in a similar case also advertised to be 8.5" outside, 8" inside, and decided it was too tight for my P3A - no room for padding. Ended up getting one of those cheap backpacks off ebay.
  9. tcope
    Salt Lake City, UT
    I've read that some people spray the foam with something to keep it intact.
    [Edit: Plasti-dip]
    I usually use an inexpensive backpack to carry my P3 but thought that there might be a time or two that I could use a hard case. I can't see spending $200 for something I'd use a few times.
    It is an option.
    #9 tcope, Sep 22, 2015
    JBG likes this.
  10. Jesse_M
    Woodland Park, CO
    I have this as well for my P1. Works awesome for the price but I agree I don't think it would work with the P3.
  11. Mako79
    Sydney Australia
  12. td619
    I just got mine for $50 shipped to the house! Took awhile to get foam cut but my P3a fits perfectly! It's a tight fit. If you do not properly get the bottom foam cut perfectly your P3 will not fit with props on. So far so good for me!
    ImageUploadedByPhantomPilots - DJI Phantom Forum1442969999.460240.jpg ImageUploadedByPhantomPilots - DJI Phantom Forum1442970014.854113.jpg ImageUploadedByPhantomPilots - DJI Phantom Forum1442970436.547500.jpg
  13. Dronebow
    Texas
    Cool. <- just wrote that so I can find this later. :rolleyes:
  14. Look eyes
Similar Threads - Weatherproof Hardcase under Forum Date
New Shell- somewhat weatherproof? Phantom 4 Discussion Mar 5, 2016
MCM Weatherproof Cases General Discussion Aug 13, 2015
Weatherproof case sale General Discussion Jul 14, 2015
Weatherproof case for your P3 Pro/Adv Discussion Apr 27, 2015
Phantom 4 with hardcase and extra batteries under $800. Phantom 4 Pro Discussion May 19, 2017
