P3 standard antenna booster
Discussion in 'Standard/4k Discussion' started by Orion55, Nov 5, 2015.
  1. Orion55
    I was going to mod an antenna booster from my p3p but found this one in stock. I know the p3s is less expensive but I have lost video and had low signal warnings under 1000 ft. so hopefully this helps. I thought about returning the p3s because of this, but need extra batteries for my p3p so I may keep it since it's only really costing me under $500 to keep it. It's nice to see a few going over a mile because mine is no where near that.
    https://www.amazon.com/dp/B016I2WENY/ref=cm_sw_r_other_awd_OtapwbBA0AXQY
  2. TG3S
    Get the DBS Itelite and you will be able to significantly increase your range.. I was only getting 1500' stock and with the DBS Itelite, my range increased to 7400'.. This was I the exact same location both times.. I'm sure in an area with no interference I'd see a lot more range..
    Long range Jim likes this.
  3. RodPad
    Pacific,NorthWet, 97031
    That won't help your FPV, just your remote controller.
    The FPV on the standard is inside the remote.
    The Windsurfer antenna I made added a surprising distance on my P3S when I tried it.
    DIY Antenna Booster for Phantom 3 | DJI Phantom Forum
  4. ChrisRN
    I just purchased this, when it arrives next week I'll let you know how it preforms. My max stock distance has been 600m from my backyard, but my neighborhood has community WiFi.
  5. TG3S
    I have tested 3-D printed boosters like these with no foil or reflective tape and have seen about 20% increase in range with a P3P..
  6. Long range Jim
    Palm beach county
  7. UASDRONE
    That did not work for me.
Similar Threads - standard antenna booster Forum Date
Antenna Range Extender Radio Signal Booster Amplifier For DJI Phantom 3 Standard Standard/4k Discussion Nov 15, 2016
Standard BlueProton DJI Phantom 3 Standard WiFi Signal Range Extender Antenna Kit by ARGtek Phantom 3 Help Aug 5, 2017
Phantom 3 standard parabolic antenna distance Standard/4k Discussion Jul 29, 2017
Aftermarket antenna for phantom 3 standard Standard/4k Discussion Jul 2, 2017
Phantom 3 Standard + ITELite Antenna Mod + Case and More Classifieds May 20, 2017
