Yes you can I've got a phantom 2 vision and I've been flying mine sense Black Friday with no problems. They seem to be more easier to instal aswell. They do have more thrustYes.
I've got some 9550's on my P2V+ too. The sound is a little different and as mcajr37 says the thrust is improved...as it should be with a 5" pitch vs. 4.3" pitch
I also find that it's a bit quicker to respond to stick inputs - so be careful if you're used to a "lazy" response.
Dang I really wanted to try the 9550s
Actually, if you order props from DJI, that's what you will receive (9450s). The 9443 props that were original on the P2V+ have been discontinued.Thanks to everyone for the responses
They supply more thrust. No disadvantages. No choice in any event, since 9443s are no longer being shipped from DJI.Are there any disadvantages for 9450 ?
My problem was that one of my four 9443s was broken. Since you can't mix 9443s with 9450s, I ordered new ones, which were 9450s. Just as well, because I'm using a Zenmuse H3-3D and GoPro Hero 3 Silver. I'm presuming I could use the added thrust since the GoPro setup weighs more than stock.I have 9443 now and I got spare 9450 so Im asking if I should change them since my 9443 are ok.
