P3 Pro Aux output / servo / parachute
Hi guys,
I'm thinking about installing a parachute on my P3P, does anyone have any idea if the is any way to actuate a servo motor using the P3P original configuration?
I remember that on the P2 it could be done by connecting the servo to the Gimbal port on the Nasa.
Any way I can install this servo to trigger the parachute using the the original controller?
Thanks much!
Reactions: Jeff Shum
I can't provide you a solution but I can give you something to look in to.
There is now a retract system for the P3 which is able to use an existing signal and a custom interface to actuate them.
Here's a link (there may be others):
http://www.savemyphantom.com/retracts
Reactions: Alexandre Bachour
Hi guys,
Thanks much!
Did you get the servo working with Phantom controls?
Jeff
shimuafeni fredrik
