*In the title I specified (android) because in test with ios, this issue does not exist.
For those of you that fly your aircraft using a Android device; while flying have you noticed when you make a change in direction say 10 degrees for example,....the nose of the aircraft turns as it should, but the aircraft continues in the existing direction somewhat before catching up with the new direction so to speak?
If are familiar with this have you tried changing gain settings to possibly work some of it out?
